12-03-2014 03:46 AM
Hello.
I have WLC5204 controller and AIR-CAP1602 access points.
I have the latest software version on the wlc.
I connect the wlc to a trunk port. i have internal dhcp server enabled in wlc.
when i connect the ap to access port same vlan as management interface vlan, the ap cannot join the controller.
the ap is assigned an ip address from the dhcp server but the following error logs are displayed:
did not get log server setting from dhcp
invalid event 10 and state 5 combination
failed to process message type 10 state 5
failed to handle capwap control message form controller
failed to process encrypted capwap packet from 192.168.1.10
I would really appreciate your help in this matter.
Regards.
Solved! Go to Solution.
12-04-2014 03:12 PM
It joined the controller and everything was fine.
It will initially join the WLC to download the full IOS but after that, because of incorrect regulatory domain, won't join the controller to provide service.
I am afraid that the problem appeared after i attempted to restore the wlc to factory settings and i was asked if i want to save the configuration on the flash before i restore, i answered no.
If the AP is to be installed somewhere in Europe, then change the Country settings (Wireless > Country) to the correct country and un-tick "USA".
12-03-2014 01:15 PM
Post the following output:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version; and
4. AP: sh ip interface brief
12-04-2014 03:30 AM
1. WLC sh sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... GDNE test
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 20.20.20.10
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 38 mins 46 secs
System Timezone Location......................... (GMT +2:00) Jerusalem
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +27 C
External Temperature............................. +31 C
Fan Status....................................... 3700 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 1C:DE:A7:06:A5:40
Maximum number of APs supported.................. 10
2. WLC sh time
Time............................................. Thu Dec 4 13:26:30 2014
Timezone delta................................... 0:0
Timezone location................................ (GMT +2:00) Jerusalem
NTP Servers
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server NTP Msg Auth Status
1 0 AUTH DISABLED
3. AP show version
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(4)JB6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 22-Aug-14 10:56 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
AP7c0e.ce85.5e74 uptime is 1 minute
System image file is "flash:/ap1g2-k9w8-mx.152-4.JB6/ap1g2-k9w8-mx.152-4.JB6"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-E-K9 (PowerPC) processor (revision B0) with 229366K/32768K bytes of memory.
Processor board ID FGL1833X71G
PowerPC CPU at 533MHz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.130.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 7C:0E:CE:85:5E:74
Part Number : 73-14671-04
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC1832800C
Top Assembly Part Number : 800-38552-01
Top Assembly Serial Number : FGL1833X71G
Top Revision Number : A0
Product/Model Number : AIR-CAP1602I-E-K9
Configuration register is 0xF
4. AP show ip interface brief
BVI1 20.20.20.101 YES DHCP up up
Dot11Radio0 unassigned NO unset up up
Dot11Radio1 unassigned NO unset up up
GigabitEthernet0 unassigned NO unset up up
GigabitEthernet0.1 unassigned YES unset up up
12-04-2014 01:40 PM
This line says the WLC is configured for USA regulatory domain.
This line says the AP is meant to be used for countries with "-E" regulatory domain, like countries in EUROPE. And this is why the AP will never join the WLC.
Go HERE for more information and/or details.
12-04-2014 02:02 PM
This access point was working fine with the controller at the beginning. It joined the controller and everything was fine.
Could this be the case ?
if yes, how can i fix it ?
12-04-2014 03:12 PM
12-08-2014 02:32 AM
Thank you very much.
Changing the country settings on the wlc fixed the problem.
However, i am facing a small issue in this matter.
I want to use the wlc and the aps in an environment where i have a hotspot server at vlan 1.
I have the guest network on the wlc configured on vlan 1.
However, guests cannot connect to the hotspot server when it is on vlan 1.
They can only connect when i change the hotspot server to any vlan other than vlan 1.
I would appreciate your help in this matter.
Thanks.
