06-15-2020 12:12 AM
I working on at large European enterprise company with multiple devices, primary switch´s 29xx, 3650, 3750, 3850, 4500, 93/9500.
I’m tasked with finding a nice an easy way, of making sure we have up to date and stable software running on all devices.
I´m looking for suggestions on the way to go forward in regards to, is there any automated or semi-automated way to go forward, using Cisco tools or Cisco software db? In order to make sure we running the preferred software? Beside manually having a look at https://tools.cisco.com/security/center/softwarechecker.x day in and day out?
Br. Jakob
06-15-2020 12:19 AM
06-15-2020 01:14 AM
Hi there,
Go to the download page for your platforms and click on the 'Notifications' link. You can then configure periodic email notifications for those platform releases. Then setup email filters to pluck out the new release emails and delete the rest (or maybe keep those ones too as they are useful!)
cheers,
Seb.
06-15-2020 04:25 AM
Hi Seb Rupik
Yeah i also had that in my mind, and maybe create a new seperat mail account in my company, for this. But i was hoping there was a more.... lets say inteligent way :)
Br. Jakob
06-15-2020 06:45 AM
Intelligence huh, that is always in short supply!
I think Cisco Prime had some sort of release notification. Solarwinds had a report your could run which would alert you.
Your best bet is to roll something yourself to suit your needs. Have a look at apiconsole.cisco.com ....you may have better access than me. I believe the 'Platform-API' contains the information you are after, although the documentation is non existent and I can't access it to confirm.
Essentialy you are looking at create a cron task to take your infrastructure platform types and query them against the API to determine if a new recommended release has been issued.
cheers,
Seb.
06-15-2020 07:35 AM
Hi Seb
Hehe yes your absolut rigth about that😭
Apiconsole.ciso.com and a auto fetch and queary job is a great ideal!
Thanks for the tip!
Stay safe
Br. Jakob
