Managing Cisco Works Logfiles - Problems Running Logrot
tim.davies
I'm trying to run logrot to maintain some large LMS logfiles.
The problem that i'm having is that when I run C:\Program Files\CSCOpx\bin>perl.exe "\Program Files\CSCOpx\bin"\logrot.pl -c
I'm getting the error message
"C:\Program Files\CSCOpx\bin\perl.exe is not a a valid Win32 application."
Any ideas?
Tim
Joe Clarke
Sounds like you're corrupted your Perl executable. You will need to either restore this from a file system backup, or reinstall Common Services.
6 Replies 6
Joe Clarke
Thanks, I'll give it a go.
Restoring the perl.exe file solved the problem. Thanks for the help.
Hi Tim,
Could you tell me how you replaced perl.exe?
Thank you
Aamir
Nevermind! found it.
Hi Aamir,
I have the same problem, could you please tell me how did you fix the problem with perl.exe?
Farzin
