Massive Commands
ricardorojas123
Level 7
Level 7
Which tool allows send script commands to many devices?
For example:
Add a new community SNMP to 80 Routers ..
Joe Clarke
If you're asking about a Cisco network management tool, that would be CiscoWorks LAN Management Solution's Resource Manager Essentials application. It has a component called Netconfig which will allow you to deploy these type of config changes to a large number of devices at once.
More on LMS as well as a free 90-day downloadable evaluation can be found at http://www.cisco.com/go/lms/ .
cameron.moody
Level 4
Level 4
Kiwi Cat Tools is quite good, it can do config backups and push commands out to any number of devices.
http://www.kiwisyslog.com/kiwi-cattools-overview/
Obviously CiscoWorks is an option as well but is more designed for a whole lot more so depending on your needs and whatever network management / monitoring software you have available.
Cameron
