MAXRUN timer expired error
Hello Community,
I am trying to execute a tcl script that I have downloaded from this site called wan_load_alarm. I have registered properly, however after registering I get the following error:
Jan 18 00:08:20.019: %SYS-3-CPUYLD: Task ran for (19884)msecs, more than (2000)msecs (284/22),process = EEM TCL Proc
Jan 18 00:08:20.627: %HA_EM-6-LOG: wan_load_alarm.tcl: 1Process Forced Exit- MAXRUN timer expired.
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:     while executing
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: "expr $txload_total + $txload "
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:     invoked from within
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: "$slave eval $Contents"
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:     (procedure "eval_script" line 7)
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: "eval_script slave $scriptname"
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: "if {$security_level == 1} {       #untrusted script
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:      interp create -safe slave
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:      interp share {} stdin slave
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:      interp share {} stdout slave
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: ..."
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl:     (file "tmpsys:/lib/tcl/base.tcl" line 50)
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: Tcl policy execute failed:
Jan 18 00:08:20.995: %HA_EM-6-LOG: wan_load_alarm.tcl: 1Process Forced Exit- MAXRUN timer expired.
The script is attached.
I was wondering if someone could help me please
Cheers
Carlton
Community,
My environment variables are as follows:
event manager environment wan_load_interface Tunnel 0
event manager environment wan_load_interval 60
event manager environment wan_load_duration 60
event manager environment wan_load_threshold 100
event manager environment wan_load_history_outfile flash:wan_load_history_outfile.dat
event manager environment _email_server 10.44.108.95
event manager environment _email_from carlton.patterson@ska.co.uk
event manager environment _email_to carlton.patterson@ska.co.uk
event manager directory user policy "flash:/"
event manager session cli username "en.bcz00513"
event manager policy wan_load_alarm.tcl
Cheers
Joe Clarke
The loop that iterates through the history file is fairly tight, and will cause Tcl to spin for a while if the file is very large.  You could add a pause of half a second per field to make sure the thread yields.  Of course, this could also have an impact on maxrun.  You'll likely want to increase maxrun, too.  You can start with 60 seconds and work up from there until the script no longer aborts.
To add a pause in that loop, insert the following after the set txload_total [ expr $txload_total + $txload ] line:
after 500
