09-23-2013 01:29 AM
Hi All,
I would like to monitor our MC3G60 linecards on our UBR10k systems by SNMP,
and found this OID:
cefcModuleUpTime -
1.3.6.1.4.1.9.9.117.1.2.1.1.8
(ciscoEntityFRUControlMIB)
when I try to walk this OID, the system returns a 'No Such Instance currently exists at this OID'
Is this the correct OID to fetch the uptimes for our linecards ?
UBR is running on 12.2(33)SCG4
10-11-2013 12:07 AM
*bump*
10-11-2013 01:25 AM
Dag Joost,
I assume you can get other OID's from this device without a problem?
What you must understand is that there is an OID and an instance. To obtain the instance(s) you should walk the OID.
So under 1.3.6.1.4.1.9.9.117.1.2.1.1.8 you may find that there are 4 instances for your card. I make up something here to paint you the picture:
1.3.6.1.4.1.9.9.117.1.2.1.1.8.1
1.3.6.1.4.1.9.9.117.1.2.1.1.8.123
1.3.6.1.4.1.9.9.117.1.2.1.1.8.124
1.3.6.1.4.1.9.9.117.1.2.1.1.8.1001
These 4 entries are then for you to collect to have the uptime of each card.
Now if the device says 1.3.6.1.4.1.9.9.117.1.2.1.1.8 does not exist when you try to do a snmpwalk, it could be a number of things.
Cheers,
Michel
