MDS 9513 clockcard DFM alert
nancyrawls
Under DFM - Alerts and Activities I'm getting a Utilization alert saying Clockcard is not present. When I go into the device it indeed says it is not present but I'm not given the option to uncheck it so that it won't be monitored. How do I get rid of this alert? See attached.
17 Replies 17
What output do you get for:
dmctl -s DFM getInstances Card_Fault_CiscoEntityFRU
We might be okay. The event just cleared when I ran the same command for the other card. Output:
I-Card_Fault_CiscoEntityFRU-CARD-123.133.187.1/1000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.187.1/2000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.187.1/3000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.190.1/1000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.190.1/2000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.190.1/3000
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/25750
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/25751
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.145/36
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.146/36
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/25750
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/25751
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.147/36
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/22
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/23
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/24
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/25
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/25750
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/25751
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/26
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/28
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/29
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/35
I-Card_Fault_CiscoEntityFRU-CARD-123.133.5.148/36
I-Card_Fault_CiscoEntityFRU-CARD-123.170.0.5/2000
I-Card_Fault_CiscoEntityFRU-CARD-123.170.0.5/3000
I-Card_Fault_CiscoEntityFRU-CARD-123.170.0.5/4000
Yeah, it looks like those subclasses are now missing from the FRU list. You shouldn't see any more events for those components moving forward.
