MIB CISCO-CLASS-BASED-QOS-MIB is supported on all Cisco Routers
loma
We have a discussion with eHealth via partners to view the QoS traffic on the routers. They stated that we should activate the MIB variable on the router. Therefore, can someone tell me if the MIB CISCO-CLASS-BASED-QOS-MIB is supported on all Cisco Routers?
Or can it be activated? This MIB tree starts at OID 1.3.6.1.4.1.9.9.166
Lode
Joe Clarke
You can use the MIB Locator to search for IOS images which support this MIB. If the image supports the MIB, there is nothing additional that must be done to enable it. Just enabling SNMP and configuring the required QoS parameters are enough.
http://tools.cisco.com/ITDIT/MIBS/MainServlet
The mib locater indicates that the mib tree exists on the router but a snmpwalk give no result:
Met OID .1.3.6.1.4.1.9.9.166
bash-2.05$
bash-2.05$ ./GetTable2.pl
No results found for 164.140.221.11 with ***
bash-2.05$
output of show version:
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXH, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sun 19-Aug-07 07:38 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
nabxpr01 uptime is 28 weeks, 1 day, 20 hours, 37 minutes
Uptime for this control processor is 28 weeks, 1 day, 20 hours, 42 minutes
Time since nabxpr01 switched to active is 28 weeks, 1 day, 20 hours, 40 minutes
System returned to ROM by reload at 09:47:37 UTC Wed Aug 22 2007 (SP by reload)
System restarted at 15:48:44 GMT+1 Wed Nov 14 2007
System image file is "bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXH.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of memory.
Processor board ID SMC11250066
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
50 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
yjdabear
Try snmpwalking 1.3.6.1.4.1.9.9.166.1.15.1.1.10 directly. This is cbQosCMPostPolicyByte64 that eHealth's QoS module uses to calculate "Post-Policy Throughput". It should be populated.
Thanks for your feedback. There was a small mistake in the configuration of the router concerning QoS which I have overlooked.
Thanks for your assistance it is working fine now.
