MIB Errors in CISCO-LWAPP-AP-MIB
carstenInfraray
Hey Cisco community,
I found some issues in the current CISCO-LWAPP-AP-MIB. I downloaded the newest one from https://cfnng.cisco.com/mibs and even there the errors exist. So I will just post them here so it will maybe reach the relevant developer / engineer:
1. Missing Imports:
CLApNtpStatus and CLDot11Band are used in the MIB, but are not imported from CISCO-LWAPP-TC-MIB. The MIB should be corrected to:
    CLApIfType,
    CLDot11Channel,
    CLApAssocFailureReason,
    CLApDot11RadioSubband,
    CLApDot11RadioRole,
    CLApMode,
    CLApNtpStatus,
    CLDot11Band
        FROM CISCO-LWAPP-TC-MIB
2. Incorrect Table Name
The newly added table cLApWlanSlotStatsTable is named wrong or all references are wrong. I assume that just the table was named incorrectly, because the reference follows the naming schema of the rest. The MIB should be corrected to:
cLApSlotWlanStatsTable OBJECT-TYPE
    SYNTAX          SEQUENCE OF CLApSlotWlanStatsEntry
    MAX-ACCESS      not-accessible
    STATUS          current
    DESCRIPTION
        "This table represents Per-AP, Per-Slot, Per-SSID
        Stats information of packets/bytes sent/received,
        retransmission counter, associated clients counter,
        etc."
    ::= { ciscoLwappApSlotWlanStats 1 }
3. Tailing Comma
There is a tailing comma after 'bsnStationAPIfSlotId' which breaks older MIB parser. The MIB should be corrected to:
ciscoLwappApRadioStuck NOTIFICATION-TYPE
     OBJECTS {
                 cLApSysMacAddress,
                 cLApName,
     STATUS     current
     DESCRIPTION
        "This notification generates when an AP detects that its
         radio is stuck"
     ::= { ciscoLwappApMIBNotifs 34 }
It would also be nice to correctly update the LAST-UPDATED field.
Best regards
Carsten
neptunium
I need more.
4. more Missing Imports:
    FROM AIRESPACE-WIRELESS-MIB
5. Missing quote :
CISCO-LWAPP-REAP-MIB.my (line 2032)
cLReapGroupPMKAPPropagation OBJECT-TYPE
....(snip)
         A value of 'pmkDistDCDS' specifies PMK distribution between
         APs in site tag."
6. more more amd more Missing Imports:
CISCO-LWAPP-DOT11-MIB.my
    RowStatus
       FROM SNMPv2-TC
CISCO-LWAPP-QOS-MIB.my
    MacAddress,
    TimeInterval
       FROM SNMPv2-TC
    Unsigned64
        FROM CISCO-TC
    InetPortNumber,
    InetAddressPrefixLength
        FROM INET-ADDRESS-MIB
    InetPortNumber,
CISCO-LWAPP-SYS-MIB.my
    TimeInterval
        FROM SNMPv2-TC
CISCO-LWAPP-WEBAUTH-MIB.my
    InetPortNumber
carstenInfraray
Dear cisco support, is there any update on this topic?
Is there something you need help with?
