MIB folder
Chris Deren
I need to put IPCC Alert MIB on the CiscoWorks server, however I am not sure where it needs to go.
Chris
5 Replies 5
nhabib
Level 9
Level 9
Which flavor of CiscoWorks are you running?
Well, I am not the administrator of the CiscoWorks server, so I am not sure. From what I see we've purchased all CiscoWorks components.
Chris
Chris, these are the CiscoWorks bundles:
CiscoWorks LAN Management Solution
CiscoWorks VPN Management Solution
CiscoWorks Routed WAN Solution
CiscoWorks for Windows
CiscoWorks Small Network Management Solution
CiscoWorks IP Telephony Monitor
They only ones that allow the loading of MIBs are CiscoWorks Small Network Management Solution and CiscoWorks for Windows.
All others do not allow it.
I have LMS and ITM. Will either one of these work?
Chris
Neither one of these applications allow the loading of MIBs
