Mini RMON
ariesc_33
Hi!
why my cisco 7300 series doen not show up in the mini RMON?
See logs below
Message
Failed to open Mini RMON manager for this device.
Cause
Mini RMON manager may not be supported on this device.
Action
Please check the Mini RMON package readme or online help for list of supported devices.
frankzehrer
Level 4
Level 4
Hi Aries,
if you are runnning LMS 2.5 pleas check the supported devices here:
- go to the homepage of CW
- click on Help
- click on Search
- enter: "supported"
- select "All Words"
- select "miniRMON"
- click on Search
- click on "Supported OIDs"
Hope the clarifies your problem.
Actual the 7300 series is not supported.
Best regards,
Frank
Thanks a lot for the info.
Anyway, is there a way for mini-RMON to support 7300 series?
It is not likely that support will be added for the 7300 series router as the majority of routers do not support miniRMON or RMON-II.
Switches are usually the devices that support miniRMON, but routers do not.
