mls netflow aso
lakn
Hi there.
I am running mls nde on 6509´s and are getting
sh ip flow export
Flow export is enabled
Version 5 flow records
60251232 flows exported in 145173954 udp datagrams
0 flows failed due to lack of export packet
11541 export packets were sent up to process level
0 export packets were dropped due to no fib
927204 export packets were dropped due to adjacency issues
those export packets du to adjacency .. Is there anyone that can tell me why, how and possibly a solution to them.
They are reported to a server that is almost idle (cpu 5 %) and a gigainterface with very low load. The cpuload on the 6509 is max 2%.
Any help would be nice.
umedryk
Level 5
Level 5
I am not really sure if this is abnormal. But if you see the number of flows failed, it is zero, and I think this is what we should be considered about.
