On most of my weekends i have to go stay in a small village in france where there is no dsl or fiber line conection possible (the village is just to small not really interesting for the isp's)
Bit I managed to put a Lte advanced antenna to catch some lte signals from 2 villages away and well repeat it into my hous wich works great and i have up to 30mbps down and 15mbps up wich I use mostly for gaming 40-60ping. But I was wondering if there is any mobile data hotspot device that would be better than using an old phone the huawei p8 lite 2017 would it amke a difference if yes woch device should I buy and I would really love if it had a lan cabel connection possibility instead of a usb tethering. Thanks in advance. Sry my english isnt the best. Im only 15 :)
