monitor event-trace arp command
markbohush
I have a C4507 core switch that because of a NEC phone system, we are having some issues with calls. What I need to do is to shut of the ARP IP monitoring on the switch. I have the command monitor event-trace arp and want to know if "disable" will stop the IP tracing and also if I I do it in production hours will it affect the people currently connected.
0 Replies 0
