Monitor L2L using Graph
Ibrahim Jamil
Level 7
Level 7
Hi Experts
what  the network tools available nowadays, to monitor site-2-Site VPN using Graph ?
can PRTG do it ?
Jamil
there are several monitoring tools out there like solarwinds, cacti(free),nagios(free) so maybe you can look around.
I believe PRTG can monitori vpn's as well. Maybe you should see their release or configuration notes
Hi!
I agree with Kishore. However, If you want to monitor real time (polling time starts from every 5sec!) you can use Cisco Configuration Professional. I do not know the type of your router but it is supported to all the new ISR G2 routers (e.g. 1900,2900, 3900...) It is free and you can download it by cisco.com with just a simple login account.
The CCP replaces the Cisco SDM and can be very useful especially for troubleshooting.
Hope that helps!
Vasilis
