Monitoring BGP using SNMP
Manoj Wadhwa
Hi Friends,
We have BGP enabled on our networks with SNMP enabled to trigger alerts in case of link up/ downs. What we observe is when BGP session goes Active (but interface is up), we do not get any alert from SNMP saying BGP status has changed. The SNMP configuration is as below. Would appreciate if you can let me know if there is anything missing or something required to the config to monitor BGP state changes. Thanks in advance.
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps isdn call-information
snmp-server enable traps bgp
snmp-server enable traps config
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps syslog
Best Regards,
Manoj
wiluszm
Manoj,
Under your BGP config do you have "bgp log-neighbor-changes" enabled? This is how we get notifications on peering status changes. Hope this helps!
-Mike
http://cs-mars.blogspot.com
