Monitoring interface traffic in Prime infrastructure 3.5
Netzwerker
We have Cisco Prime Infrastructure 3.5, T tried to add a tab under Monitor / Monitoring Tools / Performance Graphs to monitor utilization in RX and TX of a physical interface but it give me the error "No Metrics available for this Interface".
What can I do?
Note: this error is shown for the majority not for all interfaces and Netflow is not configured.
Mark Elsen
 - You may want to remove and re-add the particular device in Prime but use the button Verify Credentials first before the final add , also note that your Prime version is getting rather old, using recent version is advised , in that context also take a look at https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-5/supported/devices/PI35-Supported-Device-List.xlsx   , devices may get upgraded and become incompatible with older Prime version(s) -> Lookup your device and  check S/W column , make sure PI3.5 can still handle your device.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi marce1000,
Thank for your reply!
For the same device, I cant see interface performance (TX/RX) for some interfaces but not available for all interfaces!
I want to know if Netflow must be configured or SNMP is sufficient for this use case?
 - Prime does not need Netflow for interface monitoring , snmp  only. My arguments may still apply , if for instance these interfaces relate to new modules , and or are related to more recent hardware (for instance) or simply different types then  the ones you can monitor.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
