Monitoring SIP-UA and do actions "reload" or "re-register SIP-UA"
sSiDs
Hi team! Need your help in fine tuning EEM.
025951 is registered to registrar1 and 036751 to registrar2
everything works fine...exept SIP registration 025951 could be dropped ... suddenly, without any reason
ssip - alias to "sh sip-ua register status"
ssip runs every 300 seconds to verify that 025951 is registered to Registrar-Index 1
i do not know which way is better and do not know HOW TO configure:
scenario1: If 025951 is dropped in Registrar-Index 1, then reload router.
scenario2: If 025951 is dropped in Registrar-Index 1,remove all SIP-UA config and configure againg.
I am appreciate for any help!
R2c2801#ssip
--------------------- Registrar-Index 1 ---------------------
Line peer expires(sec) registered P-Associ-URI
025951 -1 40 yes
036751 -1 64 no
--------------------- Registrar-Index 2 ---------------------
025951 -1 94 no
036751 -1 35 yes
event manager environment i 1
event manager applet Check_SIP_registration
description applet to do a show run command to check SIP registration. If not registered, run "reload" router. Runs every 300 seconds.
event timer watchdog 300
action 100 cli command "en"
action 200 cli command "ssip"
action 250 foreach line "$_cli_result" "\n"
action 300 regexp "025951(.*) no " "$line"
action 400 if $_regexp_result eq "1"
action 450 if $i eq "1"
action 455 syslog priority critical msg "SIP account is not registered. Please check service."
action 500 mail server "10.10.10.10" to "tech@mycompany.com" from "cisco@mycompany.com" subject
"R2c2801: SIP registration is DOWN" body "SIP registration is DOWN on R2c2801. SIP account is not registered. Please check service."
action 600 cli command "conf t"
action 601 cli command "event manager environment i 0"
action 602 cli command "exit"
action 603 end
action 604 end
action 605 else
action 650 if $i eq "0"
action 651 mail server "10.10.10.10" to "tech@mycompany.com" from "cisco@mycompany.com" subject
"R2-c2801: SIP registration is back UP" body "SIP registration is back UP on R2c2801. Voice services are back online."
action 652 cli command "conf t"
action 653 cli command "event manager environment i 1"
action 654 cli command "exit"
action 700 end
action 800 end
action 900 end
sSiDs
sip-ua config
R2c2801#sh run | s sip-ua
sip-ua
credentials username 025951 password 7 xxxxxxx realm voip.voiceisp.com
credentials username 036751 password 7 xxxxxxx realm asterisk
authentication username 025951 password 7 xxxxxxx realm REGISTRAR
authentication username 036751 password 7 xxxxxxx realm asterisk
nat symmetric role passive
nat symmetric check-media-src
no remote-party-id
max-forwards 10
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 5
timers trying 1000
timers invite-wait-100 1000
registrar 1 dns:voip.voiceisp.com:9060 expires 3600
registrar 2 ipv4:10.10.10.1:9060 expires 3600
sip-server ipv4:10.10.10.2:9060
no suspend-resume
host-registrar
permit hostname dns:voip.voiceisp.com
Joe Clarke
I thought I replied to this already, but I guess CSC didn't take it.  You don't need a lot of the complexity you have here.  This applet should work for you to reload the device.  If you'd rather reconfigure sip-ua, you can add the cli actions instead of the reload action.
event manager applet check-sip
 event timer watchdog time 300
 action 001 cli command "enable"
 action 002 cli command "show sip-ua register status | begin Registrar-Index 1"
 action 003 foreach line $_cli_result "\n"
 action 004  regexp "^025951" $line
 action 005  if $_regexp_result eq 1
 action 006   regexp "025951.*no" $line
 action 007   if $_regexp_result eq 1
 action 008    reload
 action 009   end
 action 010   break
 action 011   end
 action 012 end
