Montoring IGMP on Cat3750
jumo-2006
can anyone give me a short hint, how to manage IGMP monitoring on a 3750.
I tried to do a snmp-walk over the OID for the IGMP-MIB (the UG states this MIB is supported by the software we use)but I just get an answer that the Object is not available.
A 'debug snmp packet' shows the following output:
Mar 19 10:22:21.693 UTC: SNMP: Get-bulk request, reqid 429, nonrptr 0, maxreps 100
experimental.59.1.1 = NULL TYPE/VALUE
Thanks in advance
sbilgi
Level 5
Level 5
Kindly use the following url to check that the OID is compatible wit ha particular IOS version or not.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a05.shtml
