More fun with CPUs
duncanm
I have a 7600 with a sup 720 in slot 5.
If I run cpmCPUTotal5minRev:
CISCO-PROCESS-MIB::cpmCPUTotal5minRev.1 = Gauge32: 0 percent
CISCO-PROCESS-MIB::cpmCPUTotal5minRev.2 = Gauge32: 4 percent
CISCO-PROCESS-MIB::cpmCPUTotal5minRev.4 = Gauge32: 0 percent
CISCO-PROCESS-MIB::cpmCPUTotal5minRev.5 = Gauge32: 1 percent
The entPhysicalName shows:
ENTITY-MIB::entPhysicalName.2 = STRING: Physical Slot 1
ENTITY-MIB::entPhysicalName.3 = STRING: Physical Slot 2
ENTITY-MIB::entPhysicalName.4 = STRING: Physical Slot 3
ENTITY-MIB::entPhysicalName.5 = STRING: Physical Slot 4
ENTITY-MIB::entPhysicalName.6 = STRING: Physical Slot 5
ENTITY-MIB::entPhysicalName.7 = STRING: Physical Slot 6
As you can see, cpmCPUTotal5minRev did not pull slot 5.
How do I get that?
Yes. Not every module will have a managed CPU. In this case, the RP module in slot 5 has a managed CPU.
6 Replies 6
Joe Clarke
You're not comparing apples and oranges. You need to poll the cpmCPUTotalPhysicalIndex object to get the actual entity index to use when walking the entPhysicalTable. The cpmCPUTotalPhysicalIndex object will map the .1, .2, .4, and .5 to real entity indexes.
If I run the cpmCPUTotalPhysicalIndex I get:
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.1 = INTEGER: 2017
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.2 = INTEGER: 2001
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.4 = INTEGER: 1009
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.5 = INTEGER: 4011
Slot 5 isn't given as it stops at slot 4.
Please post the walk of the entPhysicalTable from this device.
It is pretty big, let me see if I get this:
ENTITY-MIB::entPhysicalDescr.2017 = STRING: CPU of Routing Processor
ENTITY-MIB::entPhysicalName.2017 = STRING: CPU of Routing Processor 5
So, 2017 is the routing CPU on slot 5?
Thank you once again.
