MRTG to monitor CPU load on a Catalyst 6509
limtohsoon
Hi Sir,
I manage to set up MRTG 2.10.14 on a Win2K Server machine to monitor port utilizations on a Catalyst 6509.
I wanted to monitor its CPU load. I came across the following example in the MRTG guide:
# Router CPU load %
Target[cpu.1]:1.3.6.1.4.1.9.2.1.58.0&1.3.6.1.4.1.9.2.1.58.0:public@10.10.10.1
RouterUptime[cpu.1]: public@10.10.10.1
MaxBytes[cpu.1]: 100
Title[cpu.1]: CPU LOAD
PageTop[cpu.1]: <H1>CPU Load %</H1>
Unscaled[cpu.1]: ymwd
ShortLegend[cpu.1]: %
XSize[cpu.1]: 380
YSize[cpu.1]: 100
YLegend[cpu.1]: CPU Utilization
Legend1[cpu.1]: CPU Utilization in % (Load)
Legend2[cpu.1]: CPU Utilization in % (Load)
Legend3[cpu.1]:
Legend4[cpu.1]:
LegendI[cpu.1]:
LegendO[cpu.1]:  Usage
Options[cpu.1]: gauge
I included the above piece of config into my MRTG config file (I'm using my target switch's SNMP community string & IP address). It didn't seem to work; I didn't see a graph of CPU Load when I ran my MRTG.
Please help me if you know how to do it.
Thank you.
B.Rgds,
Lim TS
rmushtaq
Level 8
Level 8
You're using OLD-CISCO-SYS-MIB which is deprecated. Instead use CISCO-PROCESS-MIB which have the object cpmCPUTotalTable. http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a94.shtml can also be looked at
