Multi-line Banners
greggkelly
I have an ASA 5505 running 8.2(2).  What's the correct syntax for creating multi-line exec and login banners? The only examples that I've been able to find have very short banners.
Any guidance would be appreciated.
Gregg
AFROJ AHMAD
Hi Gregg,
You can enter multi-line commands as a part of User-defined and Adhoc tasks.
The multi-line commands must be within the tag and .
These tags are case-sensitive and you must enter them only in uppercase.
You cannot start this tag with a space.
Example
banner login "Welcome to
CiscoWorks Resource Manager
Essentials - you are using
Multi-line commands"
You can have a blank line within a multi-line command. The commands within
the MLTCMD tags are considered as a single command and will be downloaded as
a single command onto the device.
I hope this will work for you !!!
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
