Multiple defined devices for automated action in Syslog Analysis
w.kuhn
In RME>Syslog Analysis>Define Automated Action>Add>Advanced>Device Names field you can add multiple devices (according to the help file). This only seems to work when you use a wild card * but if one uses a 'space' or ; or , to separate individual device names the notification does not go through.
Working on LMS2.2
Any Ideas how to add multiple device names and how to separate them?
Will
this is an example of what I have and it works for me. I separate the IPs with a coma only, no spaces.
172.16.101.101,172.16.102.102,172.16.32.32,172.16.32.33,172.16.64.64,172.16.64.67
