Multiple seed devices
6tschraml
Level 2
Level 2
Is there a way to specify more seed devices than supported by the Web GUI of LMS 2.5? Maybe a text file that allows to add the IP adresses manually without using the GUI?
Thanks in advance.
Thomas
nhabib
Level 11
Level 11
There is no limit to the amount of seed devices you may enter in the GUI.
You may also do this in a file, but this is a dangerous endeavor as any syntax error would cause problems.
Make sure you stop the daemon manager before editing the file. The seed devices are listed in:
NMSROOT/campus/etc/cwsi/DeviceDiscovery.properties
