N5K not syncing Clock
Liad Dayan
I have a question regarding NTP ;
I connected NTP server on my N7K VDC A.
i set up that VDC A is the root clock for the entire machine (i have 4 VDCS)
all the VDCS are synced and works fine.
my problem is N5K-VDC-B that connected to N7K VDC B.
the N5K-VDC-B is configured to take the clock from there VDC  .
from some reason all my N5K is not syncing their clock.
Have idea?
Marvin Rhoads
On the Nexus 5k you need to run the command "ntp commit" after setting up or making changes to the NTP configuration. It's a config mode command.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/system_management/6x/b_5500_System_Mgmt_Config_6x/b_5500_System_Mgmt_Config_6x_chapter_010010.html#task_DCF55CD6E5F347B4B25C37B85C8378AC
