NAM-2, login issue.
andrea.meconi
Level 2
Level 2
Hello at all.
We are using two NAM-2, WS-SVC-NAM-2, with the same software 5.1(2) and patches. Users are authenticated externally by TACACS.
We note some differences on login (see attached file). Also when we login (using the same user) on NAM #1 the menù bar is missing, on NAM #2 works fine.
Any idea?
Thanks.
Regards.
Andrea
jreekers
Level 4
Level 4
Hi Andrea.
This appears to be a cosmetic issue, and I've seen this issue before if you are using an unsupported browser to access the NAM.  The supported browsers are FF3.6 and IE8.0...is that what you are using?
http://www.cisco.com/en/US/partner/docs/net_mgmt/network_analysis_module_software/5.1_2/re
lease/notes/nam512note.html#wp43061
Are you able to reproduce this issue on one of the browser versions listed above?
-Joe
jreekers
Level 4
Level 4
Hi Andrea.
-Joe
Hello Joe and many thanks for your help.
I'm using my PC with IE 8.0 to connect to the two NAM-2.
Andrea
Hi Andrea.
I thought that would be the issue...
No worries though...could you please do a "show version" from both NAM's (from the cli) and compare them?  Specifically, I would like to know if the "build number" is the same on both NAM's.
-Joe
Hi Joe.
A "show version" from NAMs...
#1
Last login: Wed Sep 26 20:23:21 2012 from 10.4.44.116
Cisco Network Analysis Module (WS-SVC-NAM-2) Console, 5.1(2-patch5)
Copyright (c) 1999-2012 by Cisco Systems, Inc.
root@nm-core11.venezia.intranet.rve# show version
NAM application image version: 5.1(2-patch5)
Maintenance image version: 2.1(5)
NAM Daughter Card Micro code version: 1.34.1.28 (NAM)
BIOS Version: 4.0-Rel 6.0.9
PID: WS-SVC-NAM-2
Memory size: 1024 MB
Disk 0 size: 40 GB
Installed patches:
Wed Apr 13 13:45:51 2011 Patch: nam-app.strong-crypto-patchK9-5.0-0 Description: Strong Crypto Patch for NAM.
Tue Apr 19 10:45:21 2011 Patch: nam-app.strong-crypto-patchK9-5.1-0 Description: Strong Crypto Patch for NAM.
Tue Sep 25 17:27:23 2012 Patch: nam-app.strong-crypto-patchK9-5.1.2-1 Description: Strong Crypto Patch for NAM.
Tue Sep 25 17:29:09 2012 Patch: nam-app-patch.5.1-2-patch1 Description: Patch 1 for NAM release 5.1(2)
Tue Sep 25 17:29:48 2012 Patch: nam-app-patch.5.1-2-patch4 Description: Patch 4 for NAM release 5.1(2)
Tue Sep 25 17:38:21 2012 Patch: nam-app-patch.5.1-2-patch5 Description: Patch 5 for NAM release 5.1(2)
#2
Last login: Wed Sep 26 20:19:06 2012 from 10.4.44.116
root@nm-core12.venezia.intranet.rve# show version
PID: WS-SVC-NAM-2
Disk 0 size: 40 GB
Installed patches:
Fri Apr 15 11:00:25 2011 Patch: nam-app.strong-crypto-patchK9-5.1-0 Description: Strong Crypto Patch for NAM.
Wed Sep 26 13:28:03 2012 Patch: nam-app.strong-crypto-patchK9-5.1.2-1 Description: Strong Crypto Patch for NAM.
Wed Sep 26 13:28:21 2012 Patch: nam-app-patch.5.1-2-patch1 Description: Patch 1 for NAM release 5.1(2)
Wed Sep 26 13:29:14 2012 Patch: nam-app-patch.5.1-2-patch4 Description: Patch 4 for NAM release 5.1(2)
Wed Sep 26 13:39:07 2012 Patch: nam-app-patch.5.1-2-patch5 Description: Patch 5 for NAM release 5.1(2)
Andrea
