NAM 3.61b schduled report issue
orochi_yagami
The issue is,when NAM 3.61b configured with scheduled export with XML format and deliver to ms outlook 2007, the OID(object ID,or protocol name)are missing, but it works fine with outlook 2003, as per highlighted in attachment.
Hope some expert giving some crue.
thanks
Joe Clarke
The data is sent in one format. The NAM doesn't know or care about the consumer of the data. It sounds like you're doing some post processing in Outlook to view this XML in a human-readable fashion. Whatever post-processing you are doing is not working in Outlook 2007. Perhaps you should check with Microsoft to see what changed between 2003 and 2007 to see if anything needs to be updated on your end.
