NAM2320 transceiver
Xiangzhen Quan
Hello
NAM2320 has two 10 Gigabit Ethernet mornitoring interface.
Does it support 1G transceiver(SFP) like GLC-SX-MMD=?
Or it only can support SFP+
Thanks!
QxiangZh
Marvin Rhoads
I believe it only supports the 10 Gbps SFP+ type of transceiver. I can't find a specific reference but it is implied in the data sheet and product installation guide. The installation guide mentions that it's a Napatech NIC in the appliance - likely this one (or an OEM variant).
The 2304 would be the recommended product if you don't want 10 Gbps interfaces. It has 4 x 1 Gbps capture ports.
Marvin Rhoads
Thanks for your confirmation!
