WCS upgrade to Prime Infrastructure 1.3
j.mcmullen
According to this doc:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/deployment_guide_c07-721232.html#wp9000642
I can upgrade directly from WCS to PI 1.3.  This doesn't seem to be the case, the "ncs migrate" command does not exist.  Looking over other posts it seems i should setup a demo version of NCS, migrate WCS data to it, then export to PI.  Problem is, the demo version of NCS is no longer on the Cisco site for download.  I opened a TAC case, but I have a feeling i won't hear anything for a while, thought i'd check here to see if anyone else has a suggestion.
Thanks!
Rob Johnson
http://software.cisco.com/download/release.html?mdfid=284206374&flowid=30982&softwareid=283927263&release=NCS%201.1.3&relind=AVAILABLE&rellifecycle=&reltype=latest
Pull your version from the link above.
Licensing NCS 1.1.1.24 won't be necessary to import the wcs data using the ncs migrate command
and the backup command used to get a backup from the NCS system.
Be sure to install Path 12 before running the ncs migrate command....
