11-11-2011 04:30 AM
Using LMS 4.1 with an address that are natted I see that
SWIM-jobs to fetch IOS-images are using the server's "un-natted" address
Can't find how to setup the nat-address in LMS so the devices uses that one instead when communicating with the server with scp for instance..
I believe this was possible in LMS 3.x, but how is it configured in LMS 4.1?
Please advice
Fredrik
Solved! Go to Solution.
11-12-2011 11:47 AM
Admin > Collection Settings > Inventory > Edit the Inventory, Config Timeout, and Retry settings > Edit Device Attributes
Cheers,
Michel
11-12-2011 11:47 AM
Cheers,
Michel
