06-23-2015 06:07 AM
My PI2.2 is behind a Firewall where my local IP address (192.168.1.2) is translated to an outside global IP address (12x.xx.xx.xx):
+------+ 192.168.1.2 | F | 12x.xx.xx.xx +--------+ +----------+
|PI 2.2+----------------+ W +------------------+ cloud +------+ device |
My problem is that I can see that PI can't download the vlan.dat file from the remote switch via TFTP as it tries with the pre-NAT'd IP as the destination server not the NAT'd address. The following output is an assembled wireshark Telnet session when PI tries to download the vlan.dat file:
switch#terminal length 0
switch#terminal width 0
switch#
switch#
switch#show privilege
Current privilege level is 15
switch#
switch#copy flash:vlan.dat tftp:
Address or name of remote host []? 192.168.1.2
Destination filename [vlan.dat]? 20150618231154954-12x.xx.xx.xx.cfg
%Error opening tftp://192.168.1.2/20150618231154954-12x.xx.xx.xx.cfg (Timed out)
switch#
switch#
switch#
I'm not suprised it times out as the remote host address should be 12x.xx.xx.xx not 192.168.1.2.
Is there a way to force Prime Infrastructure to use the NAT'd address in such cases? I was told in LMS there is an option but I couldn't find any in PI.
Gabor
06-24-2015 03:50 PM
This discussion has been modified to comply to the CSC terms of use conditions.
06-25-2015 07:09 AM
Update
This problem is present from earlier versions of PI as it was reported 13 months ago in this support forum discussion:
https://supportforums.cisco.com/discussion/12180876/cisco-prime-infrastructure-and-vlan-fetch
Unfortunately the issues is still in PI2.2 and this was confirmed by TAC engineer. Two options are:
1. Make the actual IP address of PI routable from the device.
2. Open PER request to add this in coming PI versions .
I can accept this however I think it would be great to read it somewhere in the Admin and/or design guide of PI that you are not supposed to use PI behind any network device NATing PI's IP address.
