NCS - Wired clients not showing ip address
kzeitler10
I have Cisco switches reporting to NCS, I see mac addresses but no ip addresses.  I do not see any where to add a core router or arp table polling.  Has anybody got ip addresses to report on the wired side?
csco10971283
Hi all,
Any reply here, am facing the same problem & I need to fix it urgently.
Ahmed-
Ahmed Ossama
CCIE#26611
NCS' management of wired infrastructure is very limited. The best wired management option is still LMS.
You can upgrade your NCS to Prime Infrastructure 1.2 and get some additional wired management functionality (including the ability to manage your routers and thus, I believe, get the IP address correlation with the MAC addresses) but it still lags LMS's capabilities bit.
