Need Access List Help Please
go2doug77
Would any Cisco experts be able to lend a hand with the following ACL requirements that I need to implement on a Cisco router at work?
1. Block all inbound ICMP messages with the exception of Echo Reply (type 0), and Time Exceeded (type 11). ICMP message number 3, code 4, are permitted inbound with the following exception: Must be denied from external access gateway (AG) addresses, otherwise permitted.
2. Also block outbound ICMP traffic message types except Echo Request (type 8), Parameter Problem (type 12), and Source Quench (type 4) Destination Unreachable - Fragmentation Needed and Don't Fragment was Set (type3, code 4).
3. Also block all inbound traceroutes to prevent network discovery by unauthorized users.
Thanks for any help!
Jon Marshall
Couple of points.
1) ICMP based traceroute will be blocked by your inbound access-list as there is a general deny icmp any any catchall in there.
2) For this example I have allocated the address 192.168.1.1 as the external access gateway.
3) I have used any any in the access-lists. You can obviously narrow this down if you want.
4)I have included a "permit ip any any" at the end of each access-list as there is an implicit deny so all non-icmp traffic would be blocked without this.
5) Destination unreachable is actually 3 - host/network/port unreachable. I've permitted them all.
Inbound access-list
ip access-list extended icmptypes_in
10 permit icmp any any echo-reply
20 permit icmp any any time-exceeded
30 deny icmp host 192.168.1.1 any packet-too-big
40 permit icmp any any packet-too-big
50 deny icmp any any
60 permit ip any any
Interface config mode:-
ip access-group icmptypes_in in
Outbound access-list
ip access-list extended icmptypes_out
20 permit icmp any any parameter-problem
30 permit icmp any any source-quench
50 permit icmp any any host-unreachable
60 permit icmp any any net-unreachable
70 permit icmp any any port-unreachable
80 deny icmp any any
90 permit ip any any
interface config mode:-
ip access-group icmptypes_out out
Jon
