Need confirmation OID used memory for ISE 2.6
pbogaerts
I need the confirmation if the Object ID(.1.3.6.1.2.1.25.5.1.1.2) is the one to monitor the used memory, monitoring team see more then 95% utilization  and the dashboard is showing around 75%, if this is not the right OID, can you provide the one to
use ?
Thanks in advance
Mark Elsen
                                   - I don't have the answer off-hand but from :
     https://www.cisco.com/c/en/us/td/docs/security/ise/2-6/admin_guide/b_ise_admin_guide_26/b_ise_admin_guide_26_chapter_0100001.html
  I would have a look at the variables available in the HOST-RESOURCES-MIB and check if anything aligns with what
 you want to query.
 M.
