Network Management
Labels
When a failure occurs on an ISR900 router, we restore the backup file created using `copy startup-config tftp` to the router. In this case, do we also need to back up `vlan.dat` in advance and restore it as well? My understanding is that VLAN informa...
CHISHIUNG by • Spotlight
  • 234 Views
  • 4 replies
 Hi all,I have 2 IP SLA and track and each track have EEM when they are DOWN and UP. Sometimes both IP SLA down together and multiple times. This caused the EEM in aborted. How can we know why it is aborted ?No. Job Id Proc Status Time of Event Event...
We are aware and actively investigating issues with SAML SSO failures. Customers may experience log in errors with page not found. A workaround is removing the /login/saml/email_verification from the end of the URL. This is being investigated as a pr...
CallyH by • Cisco Employee
  • 364 Views
  • 1 replies
Resolved! SNMP at 5s and 6s
Hi There,Was wondering if someone has come across this before.I'm polling a couple very limited SNMP OIDs (ifHCInOctets/ifHCOutOctets of some interfaces) at high intervals on Catalyst 9300 class switches.At 5s, the ifHCInOctets/ifHCOutOctets is very ...
alexgill by • Visitor
  • 1065 Views
  • 7 replies
Hello everyoneI want to know if you change your clock configuration each year or not ? I mean what do you do to change the summer-time each year? Because the date and the day will change every year.I mean, this year the summer-time is : 10 Mar and 3 ...
Historically I've heard of certain commands appearing in a different order for the same device configuration. In the startup config for instance you might see subcommand B before subcommand A, even if for the same configuration you used to see A befo...
amcc by • Community Member
  • 379 Views
  • 3 replies
Hi,Im fiddeling with various EEM applets and feel a bit held back by the lack of documentation. Or maybe my google-searching skills have declined. First: Is there an official documentation of variables somewhere? So far I have pretty much brute-force...
eekman by • Level 3
  • 5267 Views
  • 12 replies
Top Solution Authors
