Need for help
saroopmalhi
Please can any one help me ?
I have cisco switch and its model #  WSC3750G-48TS-S,  Is this support net flow or not.
If not so please suggest me which cisco multilayer switch support net flow.
I appreciate your assistance
AFROJ AHMAD
Hi ,
it does not supports netflow, you can confirmed that on the following
link:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/pro
d_white_paper0900aecd80406232.html
for the supported list of devices ,check the below link:
http://www.manageengine.com/products/netflow/help/cisco-netflow/netflow-ios-versions.html
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
