Need Help In Cisco 1921 router configuration
sajed
HI All !
I am new in Cisco pl help me to configure IP CAM Network
WAN IP - 103.77.XX.XXX 255.255.255.248 (PUBLIC IP)
LAN IP - 172.16.35.1
DHCP SERVER .172.16.35.1 255.255.255.224
NAT script
its a new router/me,  so please share scripts in details !
Thanks for your help
5 Replies 5
balaji.bandi
General Config should work - if you connecting to switch on lan side (change accordingly router port config)
config t
ip routing
ip dhcp excluded-address 172.16.35.1
ip dhcp pool LAN-DHCP
import all
network 172.16.35.0 255.255.255.224
default-router 172.16.35.1
dns-server 8.8.8.8 8.8.4.4
lease 7
interface GigabitEthernet0
103.77.XX.XX 255.255.255.248
no shutdown
ip nat outside
interface GigabitEthernet1 or VLAN X
no shutdown
ip nat inside
ip route 0.0.0.0 0.0.0.0 103.77.XX.YY (change YY to ISP side IP address)
access-list 100 permit ip 172.16.35.0 0.0.0.31 any
ip nat inside source list 100 interface GigabitEthernet0 overload
wr
IP CAM Network  - not sure what IP CAM network you building here - need more information.
BB
Thanks a lot for reply, Will check this configuration ...
Thanks a lot.....It Works !!
just one help need how can I access Cisco Router Via Putty from outside ? Its a public IP On WAN Side so for creating Tunnel, I need access from outside.
setup SSH on the device and VTY lines
SSH config :https://www.cisco.com/c/en/us/support/docs/security-vpn/secure-shell-ssh/4145-ssh.html
line vty 0 4
privilege level 15
password 7 xxxxxxxxxxxxxxxxxxxxxxxxxx
login
transport input  ssh
if you do not have ACL on outside, you able to use public IP and SSH to device.,
still issue post show run complete.
BB
sajed
thanks again
