Need help with eem applet - how can I define and/or use a variable to implement a leaky bucket algorithm
Alfred Johnson
I have built a simple eem applet to monitor snmp oids in the SIP user agent and take action using cli commands to re-register with a new SIP proxy.  But the applet is too sensitive and creates more problems than it solves.  To improve on it, I want to implement a leaky-bucket algorthm in an applet or applets that will accumulate SIP errors from snmp oids by adding to an accumulating bucket count, and subtracting from the bucket when successful SIP/ISDN calls occur, using other snmp oids.  I am having trouble figuring out how to define, initialize, add to, and subtract from the bucket count, as well as debugging the applet, by examining the bucket count after causing different events, and by seeing and interpreting error messages.
Below is my intial eem applet that is too sensitive:
event manager applet re-register-with-new-proxy
event tag 403 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.7.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 30
event tag 408 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.17.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 30
event tag 480 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.33.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 30
event tag 500 snmp oid 1.3.6.1.4.1.9.9.152.1.2.5.1.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 30
event tag InviteRetries snmp oid 1.3.6.1.4.1.9.9.152.1.2.8.1.0 get-type exact entry-op ge entry-val "2" entry-type increment poll-interval 30
event tag dhcp routing network 0.0.0.0/0 type add protocol connected ge 1
trigger
  correlate event 403 or event 408 or event 480 or event 500 or event InviteRetries or event dhcp
  attribute tag 403 occurs 1
  attribute tag 408 occurs 1
  attribute tag 480 occurs 1
  attribute tag 500 occurs 1
  attribute tag InviteRetries occurs 1
  attribute tag dhcp occurs 1
action 1.0 cli command "en"
action 2.0 cli command "clear host all *"
action 3.0 cli command "config t"
action 4.0 cli command "sip-ua"
action 5.0 cli command "no registrar"
action 6.0 cli command "registrar dns:ims.voip.hrndva.rr.com expires 3600 refresh-ratio 83 auth-realm ims.voip.hrndva.rr.com"
action 7.0 cli command "end"
Each time the cli actions are executed, they cause additional SIP 403 errors when a call or two fails due  to an unregistered SIP user.  Below is the leaky bucket applets I have coded.
event manager environment bucket 0
event manager applet Dhcp
action 1.0 cli command "event manager run ReReg"
event manager applet FillBucket
event tag 408 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.17.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
event tag 480 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.33.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
event tag 500 snmp oid 1.3.6.1.4.1.9.9.152.1.2.5.1.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
event tag InviteRetries snmp oid 1.3.6.1.4.1.9.9.152.1.2.8.1.0 get-type exact entry-op ge entry-val "2" entry-type increment poll-interval 60
trigger
action 1.0 multiply _snmp_oid_delta_val 4
action 2.0 add $bucket $_result
action 3.0 set $bucket "$_result"
action 3.1 syslog msg "OID: $_snmp_oid ; Delta: $_snmp_oid_delta_val ; Bucket: $bucket"
action 4.0 if $_result ge 40
action 5.0  set $bucket "0"
action 6.0  cli command "event manager run ReReg"
action 7.0 end
event manager applet LeakBucket
event tag CallsIn snmp oid 1.3.6.1.2.1.10.20.1.3.3.1.2.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
event tag CallsOut snmp oid 1.3.6.1.2.1.10.20.1.3.3.1.3.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
trigger
  correlate event CallsOut or event CallsIn
  attribute tag CallsOut occurs 1
  attribute tag CallsIn occurs 1
action 1.0 subtract _snmp_oid_delta_val $bucket
action 2.0 if $_result lt 0
action 3.0  set $bucket "0"
action 4.0 else
action 5.0  set $bucket "$_result"
action 6.0 end
event manager applet ReReg
event none
action 01.0 cli command "en"
action 02.0 cli command "config t"
action 03.0 cli command "sip-ua"
action 04.0 cli command "no registrar"
action 05.0 cli command "registrar dns:ims.voip.hrndva.rr.com expires 3600 refresh-ratio 83 auth-realm ims.voip.hrndva.rr.com"
action 06.0 wait 15
action 07.0 cli command "do show sip-ua register status | include no"
action 08.0 string length "_cli_result"
action 09.0 if $_string_result gt 10
action 10.0  cli command "do clear host all *"
action 11.0  cli command "no registrar"
action 12.0  cli command "registrar dns:ims.voip.hrndva.rr.com expires 3600 refresh-ratio 83 auth-realm ims.voip.hrndva.rr.com"
action 13.0  cli command "end"
action 14.0 end
Currently, I have started testing the applets by creating a SIP Invite retry error.  I get the following error message:
Oct 28 14:36:52.358 EDT: %HA_EM-6-FMPD_OPERAND_INVALID: Invalid operand in action, expected value within range -2147483648 to 2147483647, received: _snmp_oid_delta_va
Oct 28 14:36:52.358 EDT: %HA_EM-3-FMPD_ERROR: Error executing applet FillBucket statement 1.0
Below is the statement that is causing the error
I am doing the multiply by 4 to give greater weight to errors than to succesful calls, each of which reduces (leaks) the bucket count by 1.
I have tried turning on debug eem all, but the output is too massive to make sense of.  I am having trouble finding clear documentation on how to define the bucket variable, how to query its value interactively, and how to see errors when the applets execute.  Can anyone help?!
Message was edited by: Alfred Johnson
Joe Clarke
It looks like you're almost there, but you're missing a few '$' here and there, and you have extra ones where you don't need them.  The other problem is that you're misusing environment variables.  If you want to share a variable across policies, you need to use contexts.  Try these versions:
event tag 408 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.17.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60 event tag 480 snmp oid 1.3.6.1.4.1.9.9.152.1.2.4.33.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60 event tag 500 snmp oid 1.3.6.1.4.1.9.9.152.1.2.5.1.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
  trigger
  action 0.5 context retrieve key SIPCTXT variable bucket
  action 1.0 multiply $_snmp_oid_delta_val 4
  action 3.0 set bucket "$_result"
  action 5.0  set bucket "0"
  action 5.1 context save key SIPCTXT variable bucket
  action 7.0 end
event tag CallsIn snmp oid 1.3.6.1.2.1.10.20.1.3.3.1.2.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60 event tag CallsOut snmp oid 1.3.6.1.2.1.10.20.1.3.3.1.3.0 get-type exact entry-op ge entry-val "1" entry-type increment poll-interval 60
  trigger
  action 1.0 subtract $_snmp_oid_delta_val $bucket
  action 3.0  set bucket "0"
  action 4.0 else
  action 5.0  set bucket "$_result"
  action 6.0 end
  action 7.0 context save SIPCTXT variable bucket
  event none
  action 06.0 wait 15
  action 08.0 string length "$_cli_result"
  action 14.0 end
Joe,
Thanks for your help.  I am seeing the following error when I cause a SIP error that causes EEM to run FillBucket:
Oct 29 16:12:59.718 EDT: %HA_EM-6-FMPD_CONTEXT_RETRIEVE: Failed to retrieve context for key SIPCTXT: 'Embedded Event Manager' detected the 'fatal' condition 'could not find key'l
Oct 29 16:12:59.718 EDT: %HA_EM-3-FMPD_ERROR: Error executing applet FillBucket statement 0.5
This is coming from:       action 0.5 context retrieve key SIPCTXT variable bucket
This is the first invocation of bucket with context key SIPCTXT, which may not have been invoked.
I am going to read up on context saving and retrieving in the meantime, but if you get a chance, let me if you have any ideas on how to fix this context retrieve error.
Also, are there any other EEM applet programming guide documents you could recommend other than the one I am using now:
Writing Embedded Event Manager Policies
Using the Cisco IOS CLI
First Published: October 31, 2005
Last Updated: December 9, 2009
Alfy Johnson
Add this:
action 0.1 handle-error type ignore
action 0.6 handle-error type exit
Actually, we need to re-write more of the FillBucket applet:
  trigger
  action 7.0 end
  action 8.0 context save key SIPCTXT variable bucket
