Need help with Syslog Filter
bbecker
Level 2
Level 2
I want to create a syslog filter to not display any ACL denies or FW logs. I don't want to see IPACCESSLOGP, IPACCESSLOGRL nor IPACCESSLOGDP. What files do I need in the filter to block these from showing up?
FYI...LMS 2.5. RME 4.0.2.
Thanks.
nhabib
Level 11
Level 11
You would need to go to:
RME -> Tools -> Syslog -> Message Filters
There you can create whatever filter you like
I understand where to create them. I wanted to know in what field do I put the IPACCESSLOGP, etc. into? Mnemonic? How should it be formatted?
Thanks.
