Need to create threshold setting only for trunks in lms 4.2.2 ?
Pandian G K
I need to create threshold for only to the trunk ports can any one help me  in this ???
pandian
2 Accepted Solutions
AFROJ AHMAD
Hi Pandian,
Check the attached screen shot ,
I hope this will help
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Pandian G K,
in the following menu you can set the E-Mail Notification.
I hope this helps.
Event Sets
Admin-->Network-->Notification and Action Settings--> Event Set
Fault Notification Group
Admin-->Network-->Notification and Action Settings--> Fault Notification Group
Fault - Email notification
Admin-->Network-->Notificationand Action Settings-->Fault - Email notification
Kind regards
Mats
5 Replies 5
AFROJ AHMAD
Hi Pandian,
Afroz
Hi Afroj Ahmad,duong.nguyen7,
Thanks for your info. i wll check and revert back to you .
Duong Nguyen
Afroj nailed it.  The default settings should already been applied to the DFM.  I rarely get alerts/faults that hit the default value.  Though sometimes for testing purpose I decrease the utilization to 15-20% to help track and troubleshoot.
Pandian G K
   I have one more doubt how to enable email notification if interface utilization  exceeds above the threshhold limit what ever i have set for those trunk ports .
thanks,
pandian
Hello Pandian G K,
I hope this helps.
Event Sets
Kind regards
Mats
