Need To Generate A Report of DCR Node, dns name, Management IP, Ifname
GERARD PUOPLO
Any way to generate a report of for each device in DCR
Device name, Management IP, DNS Name, Management IP Ifname
akemp
Level 5
Level 5
Yep, you can either just do a dcrcli export of your inventory into a CSV (quickest)or create a custom report template using the inventory... only caveat would be if you are inconsistent in your selection of management interface (since not all hardware has the same interfaces available, you might need a report template per dissimilar device type)
Heres a quick approximation of such a template:
System:Name:equals:All
AND:Interface:Alias:equals:All
AND:IP Address:IP Address:equals:All
AND:Interface:Name:equals:Lo0
akemp
Level 5
Level 5
