OID Value for CPU & Memory of 4507 switch
Jagsuvce G
Pls let me know the OID for monitoring CPU & Memory Utilization of 4507 switch
9 Replies 9
Joe Clarke
What version of code is this switch running?
Pls find the sh ver details of the switch
SW01#sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(20)EW4,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 13-Oct-06 11:13 by tinhuang
Image text-base: 0x00000000, data-base: 0x011F879C
ROM: 12.2(31r)SG2
Dagobah Revision 226, Swamp Revision 34
EY-Bangalore-SW01 uptime is 3 weeks, 5 days, 1 hour, 27 minutes
System returned to ROM by reload
System image file is "bootflash:cat4000-i9s-mz.122-20.EW4.bin"
cisco WS-C4507R (MPC8245) processor (revision 4) with 524288K bytes of memory.
Processor board ID FOX1045074A
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from Reload
4 Virtual Ethernet/IEEE 802.3 interface(s)
144 FastEthernet/IEEE 802.3 interface(s)
52 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
SW01#
Jagadish G
For memory utilization, you can use the ciscoMemoryPoolTable objects from the CISCO-MEMORY-POOL-MIB. For example:
ciscoMemoryPoolUsed
ciscoMemoryPoolFree
ciscoMemoryPoolLargestFree
For CPU utilization, you can use the cpmCPUTotalTable objects from the CISCO-PROCESS-MIB. For example:
cpmCPUTotal1min
cpmCPUTotal5min
Each of these objects are in a table, so there may be multiple instances. I recommend you walk each table on the device so you can get a feel for what each object represents.
I will doing the same for generating the graph thro MRTG. But i need the OID for the same.
I dont know how to get that.
You can use http://jaguar.ir.miami.edu/~marcus/snmptrans.html to translate the object names I have provided you into OIDs. However, you will still need to query the switch to figure out which specific instances exist. Once you have that, you can configure MRTG.
Thro the URL i got these OID's
.1.3.6.1.4.1.9.9.48.1.1.1.5 Memory Used
.1.3.6.1.4.1.9.9.48.1.1.1.6 Memory Free
.1.3.6.1.4.1.9.9.48.1.1.1.7 Memory Largest Free
.1.3.6.1.4.1.9.9.109.1.1.1.1.4 CPUTotal 1min
.1.3.6.1.4.1.9.9.109.1.1.1.1.5 CPUTotal 5min
I have configured the same on mrtg and my cpu utilization is working fine but my memory utilization graph is not growing. Pls let me know that this OID for memory is correct.
Hi ,
I suggest walking through the MIB using snmpwalk tool and get the OID's and their exact values directly from the device .This way you will get the exact value that will be accepted by the device .
As I said, you need to walk these objects on the device to get the specific instances which can be polled. These OIDs cannot be polled directly. Once you have the OIDs with their instances, you can add those to MRTG to get your graphs.
