NEED URGENT HELP FOR MY CISCO 2600 ROUTER
Mark-Anthony
This machine is giving me hard time. The problem with it is that it keeps on rebooting. I have tried to even load another IOS. But it is not working out. It is bringing this output......========= Dump bp = 2C66478 ======================
2C66378: 0 0 0 0 0 0 0
2C66398: 0 0 0 0 0 0 0
2C663B8: 0 0 0 0 0 0 0
2C663D8: 0 0 0 0 0 0 0
2C663F8: 0 0 0 0 0 0 0 FD0110D
F
2C66418: AB1234CD FFFFFFFE 0 0 800261A4 2C66478 2C183EC 8000001
C
2C66438: 1 175C7D59 70600180 DCBE0B00 C164 0 100 2C664A
2C66458: 2C668E0 0 0 0 0 0 0 FD0110D
F
2C66478: AB1234CD FFFFFFFE 0 0 800261C8 2C668B8 2C6642C 8000020
C
2C66498: 1 A35C1E12 15A 8000F9F4 2C67160 0 15A 8000F9F
2C664B8: 2C677E0 0 15A 8000F9F4 2C67E60 0 15A 8000F9F
2C664D8: 2C684E0 0 40 8000F9F4 2C68B60 0 40 8000F9F
2C664F8: 2C691E0 0 0 8000F9F4 2B657E0 0 0 8000F9F
2C66518: 2B65160 0 0 8000F9F4 2B64AE0 0 0 8000F9F
2C66538: 2B64460 0 0 8000F9F4 2B63DE0 0 0 8000F9F
2C66558: 2B63760 0 0 8000F9F4 2B630E0 0 0 8000F9F
========= Dump bp->next = 2C668B8 ======================
2C667B8: 2B73E20 0 0 8000F9F4 2B737A0 0 0 8000F9F
2C667D8: 2B73120 0 0 8000F9F4 2B72AA0 0 0 8000F9F
2C667F8: 2B72420 0 0 8000F9F4 2B71DA0 0 0 8000F9F
2C66818: 2B71720 0 0 8000F9F4 2B710A0 0 0 8000F9F
2C66838: 2B70A20 0 0 8000F9F4 2B703A0 0 0 8000F9F
2C66858: 2B6FD20 0 0 8000F9F4 2B6F6A0 0 0 8000F9F
2C66878: 2B6F020 0 0 8000F9F4 2B6E9A0 0 0 8000F9F
2C66898: 2B6E320 0 0 0 0 0 0 FD0110D
F
2C668B8: AB1234CD FFFFFFFE 0 3000000 80026214 2C670F8 0 300040
C
2C668D8: 1 8DB14C70 0 8300FECE 2B050C2 0 0 8300FEC
E
2C668F8: 2B057A2 0 0 300FECE 2B05E82 0 0 300FFC
2C66918: 2B01D8A 0 0 8300FFC4 2B01ECA 0 0 8300FEC
9
2C66938: 2CD38C2 0 0 300FFC4 2CCF22A 0 0 300FFC
2C66958: 2CCF4AA 0 0 8300FFC4 2CCF72A 0 0 8300FFC
2C66978: 2CCF9AA 0 0 0 0 0 0
2C66998: 0 0 0 0 0 0 0
========== Dump bp->previous = 2C6642C =====================
2C6632C: 0 0 0 0 0 0 0
2C6634C: 0 0 0 0 0 0 0
2C6636C: 0 0 0 0 0 0 0
2C6638C: 0 0 0 0 0 0 0
2C663AC: 0 0 0 0 0 0 0
2C663CC: 0 0 0 0 0 0 0
2C663EC: 0 0 0 0 0 0 0
Then it says (Software forced reload.) Pliz help.
wiluszm
Ensure you are not trying to boot to an IOS that is too large. I would try the most recent IOS with just basic IP services. If you still receive the above output, the 2600 is experiencing hardware failure. I would try removing all WICs and booting. If still not good, you may have corrupted NVRAM that will need to be replaced.
-Mike
desai.jaideep
Level 5
Level 5
Please stopp posting in different foroums.
JD
Hello . What would you do when you experienced a torturing problem like the one I had? Ofcourse you would go to varius technicians untill you can get a solution to your problem.
I am sorry if I piss you off.
Regards.
Mark-Anthony
I would try and open the router and check if all the flash is ok or take out all WIC cards from slots and put them back again .
