Showing results forĀ
Search instead forĀ
Did you mean:Ā
needing technical suport
i have Cisco catalyst 2960 -X series switch but i can't reset it, it displays amber light on console port and it cant connect to PC so please i need your help to reset this device
marce1000
   - FYI : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/24328-156.html
 M.
