I have an interface on a IOS-XR router that I am trying to configure using netconf. I am going through the yang models, specifically the Cisco-IOS-XR-ifmgr-cfg and looking for an option to add the second-dot1q vlan tag. I am not able to find that option anywhere. Could someone help me figure out either how to add it and/or which file that option would be under. This is what it looks like on the cli:
interface bundle-ether4.1013000
description WAN-Transit"
ipv4 address 10.0.0.1 255.255.255.0
encapsulation dot1q 101 second-dot1q 3000
This is what I have on the Yang Model.
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
<edit-config>
<target>
<running/>
</target>
<config>
<interface-configurations xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-cfg">
<interface-configuration>
<interface-name>Bundle-Ether4.1013000</interface-name>
<active>True</active>
<encapsulation>
<encapsulation>dot1q</encapsulation>
<capsulation-options>101</capsulation-options>
</encapsulation>
<description>This is a test</description>
<ipv4-network xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-io-cfg">
<addresses>
<primary>
<address>10.0.0.1</address>
<netmask>255.255.255.0</netmask>
</primary>
</addresses>
</ipv4-network>
</interface-configuration>
</interface-configurations>
</config>
</edit-config>
</rpc>
