Netconf resource-denied error?
heiki saaver
Hi. I am trying to get familiarized with netconf and I have hit the wall with a resource-denied error.
The netconf server is set up on a C3750-24TS running c3750-ipservicesk9-mz.122-55.SE8.bin
The configuration is:
DLS1#sh run | i netconf
netconf max-sessions 16
netconf ssh
The netconf SSH session is successfully established from my ubuntu VM.
Then I send the XML request:
<?xml version="1.0" encoding="UTF-8"?>
<rpc>
  <get>
    <filter>
      <oper-data-format-text-block>
        <show>arp</show>
      </oper-data-format-text-block>
    </filter>
  </get>
</rpc>]]>]]>
to which I get a reply:
<rpc-reply xmlns="urn:ietf:params:netconf:base:1.0">
  <rpc-error>
    <error-type>rpc</error-type>
    <error-tag>resource-denied</error-tag>
    <error-severity>error</error-severity>
    <error-info>
      <bad-element></bad-element>
    </error-info>
  </rpc-error>
</rpc-reply>]]>]]>
I dont understand what does this error exactly mean.
From http://xml.coverpages.org/IETF-RFC4741.txt I can see that:
   Tag:         resource-denied
   Error-type:  transport, rpc, protocol, application
   Severity:    error
   Error-info:  none
   Description: Request could not be completed because of insufficient
                resources.
Any help is appreciated!
tanh00002
Hi heikishv1
Did you solve this problem. I have the same problem. I think this problem occurred because the privilege of user who sent request from Netconf client. So I used user account which have privilege 15 but at Netconf Server, Netconf display priv=1 and problem still occured.
If you solved this problem, please give some tips. Thank you!
Sorry for the late reply.
I did not resolve it. I also haven't had time to play with it more. Maybe I will come back to it some time and try with newer Catalyst software.
rahul_mu8
i faced this issue and found cisco needs message-id to be sent in rpc tags
so below should be your first 2 tags in netconf request
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
