netconfig devicefile invalid argument
durale1789
Level 3
Level 3
I use LMS 3.1
I run exactly the same command but I get th following message:
cwcli netconfig createjob -u admin -p password -devicefile /opt/CSCOpx/bin/test.list -commandfile command.file -policyfile policy.in -description "cwcli netconfig job" -mode config
<cwcli> FATAL - NETCLI014:Netconfig createjob command failed
<cwcli> FATAL - Invalid argument: officeuk
my test.list file content is:
cat test.list
officeuk
The weird thing is that if I run the same command but without having a file but device (-device officeuk), it works!
I can't see any reason why this is not working, can u?
what is the correct argument did i miss something? I read the netconfig's manual and it is said to enter devices name contained in RME database.
regards
alex
Joe Clarke
This is a bug in the documentation. The device file must be an extension of the regular CLI. So, the syntax is:
-device device1[,device2[,device3[,...]]]
In your case, this will work:
% cat test.list
-device officeuk
Joe Clarke
% cat test.list
-device officeuk
it worked! thank you very much
i guess if i have more then 1 device the file will contain something like that:
- device device1,device2,device3,etc...
regards
alex
thank yu very much it is working by now
