While deploying config changes using a User-defined tasks over a group of 3750 switches, one switch in the group will fail with the following message:
Message: Deploy command partially failed
TFTP: Failed on the device. Insufficient no. of interactive responses(or timeout) for command: macro name staff.
Could not synchronize RME archive with Device Config
The commands work perfectly well on every other switch in the group: and we are not requesting a Synch before running the job.
All switches are running the same version of IOS. Any suggestions as to why this is failing (one switch in 10), would be appreciated.
