Netflow analyzer
farkascsgy
Level 8
Level 8
I collect netflo records with flowd opensource netflow collector. Flow version is 9. I would like to do some analysis on the collected data. Does anybody know a very good tool for this issue? If it's possible I prefer opensource..
Thanks your help in advance
bye
FCS
11 Replies 11
David Stanford
Jan Nejman
Level 7
Level 7
Try out our software Caligare Flow Inspector, it has implemented huge statistics. You can also access directly to the MySQL database and select what you want... (http://www.caligare.com/netflow/cfi.php)
Jan
you can use Netflow analyser from Adventnet.
http://download.adventnet.com/products/netflow/2028821/ManageEngine_NetFlowAnalyzer.exe
We use it but have configured a flow version of 5. I dont know whether it suports version 9 though
Narayan
Thanks your replies...
I found a very good opensource Netflow Analyzer
http://nfsen.sourceforge.net
Let's check it...
bye
FCS
Hello
which model supports netflow function,I have a 3725 model router,is it support?is it have IOS version limit?
can you share this document?thanks!
I'm sorry, but I thing that Netflow is NOT supported on this box.I think that netflow is not supported on the following series: 2900, 3500 and 3750. On the 4000 series you need a special netflow card.
Have a nice day,
Jan
I checked the 3750 and netflow officialy not supported, but version 1,5 and 6 are available...
bye
FCS
Please rate me if I helped.
I knwo that you can configure netflow on this box, but no netflow exports are generated. Before 2 years I tested 3550 box and this box sent some netflow exports, but not all (I tip that only information about first "routed" packets, I think that rest of the flow was switched and these packets wasn't included in the netflow). Last year we upgraded IOS and netflow was configured, but there weren't any netflow packets.
andyc2002
when I set netflow in 3724 router,I can't get the netflow data in our log server,is it 3700 serial router issus?In 2600 router,I can get,why?
I checked that in 3750 Cisco doesn't support Netflow officialy. This HW is not capable to do Netflow export...
bye
FCS
sir
can you tell me which model support Netflow?can you give me these document,thanks
