netflow basic question
smivanowsky
Community Member
I have a 4507 with Netflow. Am I correct in understanding that I can only see the flow of one interface? I want to try netflow but am moving cautiously and know there is a lot of traffic on this switch as it has 75+ servers connected.
Collin Clark
You can see flows for multiple interfaces. You must configure each interface for netflow with the following command:
ip route-cache flow
I put that command at the top level; that is not as part of an interface and I have seen lots of flows when I do a sho ip cache flow. My guess is that I am looking at all interfaces and if I wanted to troubleshoot one interface then I would apply the ip route cache flow to a specific interface. Is this correct?
